Home Forum Ask A Member OMC magneto wave washers
  • #10811
      Are all the magneto wave / friction washers the same on the Omc
      universal magnetos? My RDE-17 didn’t have one as it was set up
      with remote controls, but I may want to add a tiller so
      I can test out the motor yet this summer.
      I see several on EBay, but they’re not all the same part numbers.
      The parts manual doesn’t even show the wave washer that I can see.
      Thanks.
        I don’t think the RD-17 tiller motor used a wave washer. Instead, it had a tapered friction plug in the tiller twist grip.
        #80938
          Frank, I was going to borrow a tiller arm off an 1957 Big Twin
          to try out the 1955 RDE-17…… if it fits.
          I was thinking all the OMC twist grip motors of the "universal magneto" period,
          had a friction block in the tiller arm, and a wave washer under the magneto, if they
          weren’t hooked up to remote controls. Sounds like I’m wrong.
          Thanks!
          quote FrankR:
            I believe the ’55 tiller used a stamped gear while the ’57 uses a cast gear. You will have to "borrow" the gear & shaft out of the ’57 as well as the tiller. . . 🙂
            #80950
              The wave washer was used on motors that had a sliding speed control AKA the 3hp JW, etc.
              #80951
                Guess I’m more used to working on the smaller hp, earlier 50’s
                OMC’s, seeing that wave washer. Thanks for straightening me
                out…… and that saves me $10 not looking for a wave washer!
