Home Forum Ask A Member OMC Portable 6 gal Tank Bottom Molding
  • #8223
    James Seufert
      Back in the day OMC made a while rubber molding that could be fitted to the bottom of their 3 and 6 gal metal tanks. I had one on every tank I owned. I’m restoring an old tank and need a new one. They were used to keep the tank from scratching the deck.
      Anyone have a part number that I could search, or even provide the proper terminology for the part?
      #64855
      rudderless
        Its an automotive item. Try windlace…or auto trim…
        #64878
        rmhxruss
          Tempo 600TTG 300020. Tempo is out of business. Could be new old stock around.
          #64879
            Scroll down the page a bit and these guys have them for $12.95 in their ‘Close Out’ section.
            http://www.crisfield.com/gold/store/index.htm
            #64880
            opposedtwin
              James Seufert
                Thanks to all. I found several sources now. Never even heard of the term "windlace"….LOL.
                #64897
                rudderless
                  My dad built cars for a hobby in the 30s and 40s and windlace was a term he used to use for a certian body trim molding.
                  #64959
                  amuller
                    I used to use this stuff but many people have found it to trap water and rust the tank. If I were to use it now I would just put a few short pieces at the corners.
                    #64961
                    1957evinrude
                      Good Idea. I have a rubber mat that I put the tank on.
                      #64980
                      bill-loveland
                        quote amuller:
                        I just applied another similar product (sold as "truck and van door trim") to one of my tanks. I think I’ll drain it this winter, clean up the rim and give it a good couple coats of paint before I put the protector back on.
                        For years we used a rubber mat and while it protected the bottom of the boat (fiberglass) it always trapped water and grunge under it
