Home Forum Ask A Member Oops…My armature plate doesn’t fit.
  • #283664
      I have been working on a 1957 Johnson QD18 10hp. I rebuilt the powerhead. As I tried to replace the armature plate that the coils are installed on, I found that it won’t fit easily over the end of the crankcase. I think I can get it to fit on the top of my powerhead but once on it certainly will not move or advance as the throttle is opened. I know that the plate should move freely.
      This is my first time working on an outboard, first time rebuilding a powerhead. I think that there must be an issue with how I re-assembled the crankcase, and the two halves are not mated as they should be. Can anyone think of another reason the coil plate doesn’t fit easily
      '57 Johnson QD18 10hp
      '53 Sea King 3hp
      #283667
        Well it looks like I jumped the gun. Both the plate opening and the crankcase shoulder, after a good cleaning and buffing are now fitting just fine…Whew!
        '53 Sea King 3hp
        #283668
          got a copy of the johnson  bible aka  RED BOOK  to work on your oldy  ?
          https://watercraftmanuals.com/outboard/johnson/manuals/johnson-302231.htm
          #283677
            One thing you need to check – it looks in your pictures you may have the lower retaining ring installed upside down.   The flat side of the ring faces up with the beveled edge side of the ring facing down toward the crankcase.
            #283684
            William MacNeill
              I shared a link to my google drive for anyone that may need a copy of the manual
              https://drive.google.com/file/d/1ENXLxO2Z6p4oSkQmJYOsRszO4U8Sfvnj/view?usp=drive_link
              #283686
              aquasonic
                Unfortunately, many of the parts manuals that I’ve seen mistakenly show the retaining ring upside down.
                Improvise-Adapt-Overcome
                #283703
                  Indeed they do.  I made a random search through a number of my OMC parts manuals and probably half of the diagrams show the ring upside down.
                  #283754
                  John Gragg
                    I found the same issue (the hard, water-in-the-gearcase way) on the gearcase to exhaust housing gasket on my TD20. Ugh!
                    John Gragg
                    RIverside, CA
                    Just starting in the hobby, please be patient.
                    48 Sea King 5hp GG9014A. Sold
                    49 Sea King 5hp GG9014A
                    48 Johnson TD20. Sold
                    49 Johnson TD20. Sold
                    54 Johnson QD15. Sold
                    55 Johnson CD12. Sold
                    57 Johnson RJE-19M
                    57 Johnson RDE-19
                    #283812
                      Thanks,
                      I will check that and correct it if indeed I have it in upside down.
                      '53 Sea King 3hp
