Home Forum Ask A Member Outboard BarrelTest
  • #3815
    mercuryman
      Can a small motor like a Merc KE4 get to full power in a 55 gal barrel. I have a Tiny Tach and I get about 3600 RPM.
      #33265
        Nah, it was designed to run on a boat on the lake, not in a barrel. The boat moves away from the prop thrust, a barrel can’t go anywhere. I’m surprised it runs at a steady enough RPM to get a tach reading.
        #33274
        creekrunner
          That’s what test wheels are for………..or you can cut down a suitable stock prop that needed repair anyhow………
          #33283
          wiscoboater
            Creekrunner, Do you have any pictures or tips on cutting down a stock prop? I would like to see how this is done to make my own for testing.
            Thanks,
            Jeff
            #33392
              It is usually done on a lathe to evenly reduce the diameter. This ignores the fact that water flow reduces the pressure and temperature of the exhaust, but is usually OK for short runs. Remember the horse power produced is absorbed by the water and shows up as increased tempriture. Also on long run times the exhaust has a tendency to aureate the water. This mix can reduce its cooling efficiency in the outboard. Many reasons why a larger water capacity is desirable. It almost goes without saying that a fan should be used to keep the exhaust away from the carburetor air intake.
              Note third paragraph – this test was done in 1952 . . . 😉
              #33395
              mercuryman
                I guess that answers my question a small engine won’t reach full power in a barrel. If I tried that with my Super Ten Merc it would through out all the water. Very interesting report Gerry.
                #33400
                wiscoboater
                  Thats a really interesting read Gary. Thank you for posting that.
