Home › Forum › Ask A Member › Outboard Mechanic or Mentor near Gainesville, FL
- This topic has 7 replies, 6 voices, and was last updated 10 years, 4 months ago by
mr-asa.
October 7, 2015 at 3:34 pm #2720
Hello fellow antique outboard enthusiasts,
I live in Micanopy, FL. A few miles from Gainesville. I am inquiring to see if anyone local knows a mechanic or paid/unpaid mentor to work on old Mercury engines. I called an outboard mechanic on Craigslist, but he does not work on pre-1970’s engines. I am also willing to work on it myself and learn about it, I just have limited understanding of outboards with nobody to ask help from.
I have a 1959 Mercury Mark 58AEL that needs some tune up work. I have an original shop manual. The upper is mounted on a 16ft 1960 Thompson. I have the lower removed and sitting on my work bench.
1. I purchased a new impeller, water pump cover, and Mercury water pump cover removal tool. The water pump cover is stuck at the moment. I purchased the NOS cover in case the existing cover gets ruined in attempt to remove it. I ran the engine in both a garbage can of water, and in a dock at Newnan’s Lake, there is no stream of water coming out. Hence, I’m sure the impeller needs replaced.
2. I purchased replacement seals for the lower unit, I would like to replace all seals and change fluids. Also, a light brown fluid was seen running down the outer lower unit housing?
3. A minor starter solenoid issue, but less pressing as I can jump it with a screwdriver. The current starter solenoid has 3 posts, and is held on by a metal hose clamp. I purchased a used solenoid from ebay, but it only has 2 posts. I tried replacing it, the replacement solenoid with 2 posts was very weak, so I kept the original 3 post on for now.
There’s probably other small issues that are on it. I noticed the electric choke doesn’t work. The pull-start on top does not function either.
I would love to have this boat on the water this winter. Thanks for any help you can provide.
October 7, 2015 at 7:58 pm #25275Anonymous
call me I may be able to help over the phone. 1 914 310 7086. Dave.
October 8, 2015 at 1:24 am #25281Getting into old Merc outboards, you really should acquire a Mercury Service Manual, 1965 and prior. One on eBay now:
http://www.ebay.com/itm/111791698899?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
JW in Dixie
October 8, 2015 at 11:04 am #25287Yes, I own the 1965 & prior service manual. Extremely useful.
October 9, 2015 at 2:59 am #25331Did you get my PM ?
October 9, 2015 at 8:37 pm #25363Yes, thanks for the contact Garry. I’m going to email another Gainesville member that PM’D me as well. I plan on working on the engine on Monday and seeing what I can do.
quote Garry in Tampa:Did you get my PM ?
October 9, 2015 at 10:57 pm #25365Just a little info – I bought a lower unit re-seal kit (or separate parts) from Old Mercs, the square Oring that goes on the bottom of the impeller cup was too thin and wouldn’t seal at all.
October 10, 2015 at 12:59 am #25371If nothing else, try and come to the Florida AOMCI chapter meets. I usually get whatever help I need there.
http://www.flaomci.com/index.html -
