Home Forum Ask A Member Outboard motor manufacturer
  • #268799
    Frank Cornine
      I recently purchased this outboard from a small engine repair shop for $30. Someone painted over any decals and data plate (couldn’t locate any) so I could not determine any information about this unit. It is a single cylinder water cooled motor. The side covers were removed when I got it.  If anyone can help me identify make, model and year, I’d be thrilled! I have attached several photos.
      Thanks,
      Frank
      #268814
        One of the Gale variants. (1940’s)
        • This reply was modified 3 years, 4 months ago by frankr.
        #268816
        Frank Cornine
          Thanks for the quick response. I’ll start researching into Gale outboards….
          #268825
            Maybe a Gale-built Goodyear Sea-Bee.
            • This reply was modified 3 years, 4 months ago by Bob Wight.
            #268827
            Frank Cornine
              Thanks Bob, I’ll check into that.
              #268832
              JOSEPH BRINCAT
                If there is remnants of original blue and yellow paint, that would point to a Sea Bee
                #268834
                Frank Cornine
                  Joe, Someone did a really bad job of painting the entire motor blue and white with a brush and covered whatever original paint and decals were on it. At some point I will start stripping the paint off to see what remains underneath. The more pictures I see of older Sea Bee outboards I believe that’s what it is.
                  #268860
                  JOSEPH BRINCAT
                    Typically, the run -of -the mill homeowner paint is not nearly as durable as the factory stuff, Good chance that with the initial application of a chemical stripper, you will see the original paint.
                    #268861
                      Which do you want it to be?  Choices are Western Flyer, Hiawatha, Sea Bee, Sea King.
                      #268871
                      need2fish
                        + Viking,  Atlas, Brooklure , made in 1.5, 3, 5 and 12 hp.
                        I have all 7 white labelled  1.5  and the Evinrude version (weedless) a close relative, along with several 3 & 5 in various condition.
                        The serial # plate should be between the 2 transom clamps. The tank looks like it is for a Sea Bee.
                        I believe you have a 3 hp, but the cast iron jug looks like it’s from an Evinrude Sportsman (around ’47, ’48) . As far as I know Gale 3s have an all-aluminum crank case and jug… Maybe Frankr can straighten that out.
