Home Forum Ask A Member Outboard Motor Stand
  • #9640
    kevinrude
      I recently picked up a motor stand that looks like the one in the picture. Quick Question: What is the bracket that the red arrow is pointing for? Thanks.
      #73975
      dan-in-tn
        I always thought it was to put the fuel tank on, but when you tilt the cart WAY back they fall off. Other than that I have no idea?
        Dan in TN
        #73977
          To carry the pressure tank on? Or a bumper for when you have a bunch of loaded stands and you’re trying to display them all on the showroom floor? Not sure.
          #73978
            There was a strap to hold the gas tank in place.
            #73982
              It’s for the gas tank.
              #73989
              kevinrude
                OK, so the tank would lay as it normally does and then the strap, I guess, would be fastened by the same bolts that are fastening the bracket to the stand? I should be able to find some strapping lying around the house somewhere. Thanks guys.
