Home Forum Ask A Member Painting Merc lower unit
  • #262613
    Samuel Phelps
      Couple questions… What grit do you painters usually go down to before prime . After coming out of blast cabinet the surface is a bit rough . My thought was down to 220 grit . I’ll be using epoxy primer with PPG polyurethane single stage enamel.
      Also there is a small tear shaped divot on the leading edge . It has a very small hole in the divot .. Does that belong there ? I have also heard that the 2 small holes at the SS cavity should be drilled out to a slightly larger diameter. Any truth to that ?   Thanks guys ..
      #262616
      Samuel Phelps
        Here is the divot …
        #262625
          Yes it should be there. I open it up to 1/8in hole make sure to clean the cavity the hole drains.
          #262626
          Samuel Phelps
            Thanks Dave , so a total of 3 drain holes .. I’ll drill before paint then run bit back through afterwards ..
            #262630
              Dave knows better than me but I have never seen a drain hole in that area that has relief in front of it, like that. It’s almost as if it is designed….or somebody modified it……to actually pick UP water as the gear case moves forward. It seems very counter-intuitive to a drain hole, although I KNOW it IS supposed to be a drain hole…..I don’t get it.
              #262633
                Bill what the groove does is it picks up water and helps to keep the cavity hole clear. works but you need the hole bigger. when i drill the hole, I give it a tilt forward also.
                #262638
                Samuel Phelps
                  Drill at a forward angle as to pick up water better ..
                  #262639
                  bkrsdoz
                    I use Rustoleum Matte Nickel paint. Perfect match!
                    #262647
                    Samuel Phelps
                      I have the VW Cashmere to mimic the cloud white .
                      But to me it looks a little to bright white . I may experiment with some light brown paint I can add to it to give it a tinge of off white /antique white ..
                      #262648
                        Yes, drill to pick up water.
