Home Forum Ask A Member part#help
  • #3823
    wiscoboater
      Hi guys,
      My computer crashed and died the other day, taking all my stored info and part numbers with it. Can someone please give me the part number for an OMC carb kit with float for a 1956 FD 10?
      thanks
      #33310
      opposedtwin
        float 375919
        float valve/seat 375985
        bowl gasket 302994
        dan gano has all that stuff
        http://www.ganotech.com
        #33312
        wiscoboater
          Thanks Scott. It’s going to take some time to get all my info loaded to the new computer.
          #33317
            Sierra Part number is 18-7043, no float.
            The BRP number is 398532 with a float, also known as 778152, Or….
            439071 with a float. Also known as 777721
            EDIT: Made a correction thanks T2! We have both found that the 398532 is usually the best deal, and lists for about 5 dollars less than the others, as it does not have as many extra items that are un necessary for the model you need as the other kits.
            #33320
              375919 (cork) float replaced by 396514 Nitrophyl float.
