Home Forum Ask A Member Phelon Condenser Replacement
  • #10937
    wbeaton
      Is there a better source for Phelon condensers Mercury 398-693 or Sierra 18-5206 out there? I can’t find a source for less than $18 CAD. I can order them at $10 USD, but that turns into $18 CAD to my door. I can buy them from my local dealer at that price. I would even consider an equivalent. I need to make a bulk purchase (20) and would like a better price if possible.
      Wayne
      Upper Canada Chapter
      uccaomci.com
      #81603
        use a 600v capacitor of the value you need and mount it in the gutted condenser can. cost about $1.00 each if you buy quanity.
        #81604
        mercuryman
          Capacitor for Phelon is .15 – .19 uf look on Ebay .18 uf 600 volt capacitor .
          #81609
          wbeaton
            Thanks. I’ll give them a try. I thought the single wire leads might be too fragile for this application.
            Wayne
            uccaomci.com
            #81611
              use a linier cap. drill a hole in the bottom of the condenser solder the wire in the hole pull the cap down as far as possible then solder the wire from the original condenser. and use the old parts to cap things off. use some hot glue to keep things in place. can look close to original.
              #81616
              wbeaton
                I’m really not worried about originality under the flywheel. Working properly and reliably is all that matters
                Wayne
                uccaomci.com
                #81634
                Randy in Tampa
                  NAPA, RR176 😎
