Home Forum Ask A Member Pilot shaft nut
  • #276830
    Murphn8r
      Hi I have a 54 evinrude 25hp that I’m trying to get the pilot shaft nut off. I’m just curious if there is a trick or if its a reverse thread or if mine is just welded on lol. I have been trying to turn both ways just can’t seem to get it lose.
      <!–more–>
      #276833
        Sorry, but not sure what a pilot shaft nut is…  Are you speaking about the flywheel nut on top of the engine?
        #276838
          steering friction nut likely…. maybe ….. soaking and  patience  needed…some heat or cold
          #276840
          Murphn8r
            There should have been a photo attached. I’ve done heat and it’s soaking now.  I got it to turn clockwise a bit but not the other. But if it’s not reverse thread then I’m just tightening it lol
            #276842
              no reason for  reverse thread  imho…. just   keep soaking and turning
              #276864
              olcah
                https://www.aomci.org/forums/topic/steering-friction-adjustment-screw/
                Some excellent info here.
                #276882
                Murphn8r
                  so this is the nut im talking about #29 in the pictures(hopefully they upload this time)
                  #276885
                  Murphn8r
                    here is the nut, it is a lot cleaner now lol
                    #276894
                      Judicious use of the torch, liberal amounts of penetrating oil and copious amounts of patience should eventually loosen it up.   Patience is key.
                      #276895
                      Murphn8r
                        I brought it to work to see if one of the techs can get it loose. Fingers crossed
