Home Forum Ask A Member Power Head Cross Reference for 1958 Evinrude Fisherman 5516
Viewing 10 posts - 51 through 60 (of 60 total)
  • #257670
      What part number do you have for the ring set?  I will look into it.  Don
      #257686
      Mike Nazarenko
        Thank you I have the parts on order.  Hopefully to receive next week.
        #257690
          How many sets did you order?  Looks like those kits include only two rings per piston, you need three.  I will have a look around.  D
          #257723
            Broke a ring?   To help prevent this from happening, don’t use a ring compressor on pistons with aligning pins for the rings in them.  It is next to impossible to get all of the rings lined up correctly before tightening the compressor.  Instead, install them one at a time, starting with the bottom ring and working your way up.  Once the piston with the bottom ring is in the cylinder, the next ring can be installed on the piston and so on. Usually the rings can be squeezed down enough with your fingers to get them in the bore as there should be a small taper at the top of the cylinders to help them compress enough to slide in.  A small pin punch or something similar can also be used to push in any high spots your fingers can’t.  Keeping everything flooded with TCW III oil helps to.
            The current P/N for 5.5-6 horse std. size rings is 378432 (778344) and 378437 for +0.020 rings and they are gapped at 0.005 to 0.015.  I try for 0.007 which is slightly above the lower limit. The gap should be checked at the top, middle and at the end of their travel below the ports.  The gaps will probably be different at all three locations so use the tightest area in the cylinder to set the gap.
            In the past, I’ve notice new OMC-BRP rings don’t need any filing as they are made so well to specs. However, a bunch of  old Perfect Circle rings I have need the gap set everytime I install them, which is kind of nice as I can set them to what I want.
            • This reply was modified 3 years, 11 months ago by Mumbles.
            #257729
            Mike Nazarenko
              Great advice.
              Was on the last ring, had it at the top of the bore and was gently tapping the top of the cylinder and it went “bink”, it was its time. Better now when everything is apart.
              At Fleetwin’s  suggestion I’m going for all new rings.
              Locating them has not been easy. But I’ll know in a few days.
              #257739
                Mike Nazarenko
                  Thanks for the reference.
                  Saw this website yesterday, my phone said non secure, I just couldn’t give them my personal information.
                  If someone has ordered from them it would be nice to know.
                  #257762
                    Here’s one set:
                    http://www.2040-parts.com/ring-set-378432-0378432-1968-79-6hp-omc-johnson-evinrude-outboard-motor-boat-i392357/
                    I found this also.  I would give the place a call, the name of the business is located at the bottom of that thread.
                    Mumbles is absolutely right, never attempt to use a conventional ring compressor on a two stroke with locating pins.  Sorry that I have never mentioned this to you.
                    #258867
                    Mike Nazarenko
                      Thank you to everyone to helped me getting my 1958 Evinrude 5.5 hp running.  Particular thanks to Fleetwin and FrankR.
                      Ended up installing 6 new rings that I purchased from a seller in Athens, Greece.  They were a perfect fit and reasonably priced.  In addition, the new connecting rods and sealing the case back together went very well.  Biggest obstacle in the reassembly was getting the cowl back on, don’t know what Evinrude engineers were thinking when they designed it.
                      Videos of the engine running.
                      https://youtube.com/shorts/862UVXcLvMc
                      https://youtube.com/shorts/yIW9y7sh7EM
                      #258869
                        That’s a nice sounding Evinrude!
