Home Forum Ask A Member power head sealing
  • #201092
    Ralph Simmons
      i working on a OLIVER 5 1/2 hp motor replaced power head gasket .
      Will it need sealant also ?
      The gasket i cut from gasket material from napa its rubber coated
      thank you ralph
      ralphsimmons1234@gmail.com
      • This topic was modified 5 years, 10 months ago by Ralph Simmons.
      #201094
        An ongoing debate. Actually, it’s up to you.
        #201096
          is it going to be strong enough ?? some gasket have a metallic rim crimped all around the cyl openings
          #201097
          Ralph Simmons
            I am not sure about the gasket also
            the gasket with the metallic rim i didn’t know about
            not sure if i can get one have to see if someone can one
            #201098
            Geer Pyron
              Head Gasket, between cyl head and block, or gasket at base of power head between case and exhaust housing/lower unit?
              Doesnt really matter which, I’ve read a lot of posts about this and frankr is right.
              But…
              I put a little, thin coat of something anywhere exhaust might escape just to keep things a little cleaner.
              G
              JMGP
              #201100
              Ralph Simmons
                sorry didn’t make it clear my mistake
                I am talking about the cylinder head cover gasket
                problem with low compression  60/90 psi
                motor will fire up with starting fluid but would not run on gas
                it could also be in fuel pump this motor has a rubber diaphragmon side motor
                #201101
                  I would use the oem head gasket
                  #201120
                    Gale 5-1/2??? We don’t even know what motor we are talking about. But later posts suggest a Gale 5hp. They don’t even have a cylinder head gasket. But they do have a cylinder water cover gasket. No copper fire rings on those. Furthermore there are two types of Gale 5hp powerheads. Assuming the ones with a gearshift. Yes, my personal opinion is use sealant on the cover gasket on that type.
                    #201157
                    Ralph Simmons
                      sorry any confusing this a Oliver 5 1/2 motor model J2 i stand corrected
                      is a gear shift motor
                      thank you for replys
                      • This reply was modified 5 years, 10 months ago by Ralph Simmons.
