Home Forum Ask A Member Powerhead For 1958 Johnson Super Seahorse RDS-20
  • #3567
    sandman
      Hey guys,
      I am doing a full on nut and bolt restoration on a 1958 Johnson Super Seahorse 35 HP RDS-20. The original powerhead and pistons are pretty much toast but the rest of the components are still in great shape. Does anybody know if a Powerhead from a 1959 Johnson Super Seahorse 35 HP is a direct swap? If not, is there an Evinrude model from the same year that would be a direct swap? Thanks for much for any help and advice. I have been researching and found that the 1957 Powerhead won’t work, I am hoping the 1959 Powerhead will work since there is one on Ebay reasonably priced right now. http://www.ebay.com/itm/VINTAGE-1959-JO … 5C&vxp=mtr
      If anyone here has a 1958 Powerhead, I would be very interested.
      Thanks,
      Sandman
      #31397
        The ’59 should be a direct swap. Also, a 1958 Evinrude Lark is a direct swap for the 1958 Johnson SSH. Likewise, 1959 Evinrudes. If you want to sneak a 40hp in there, 1960-61 models will bolt up with minor mods.
        #31413
        sandman
          quote FrankR:
          Thank you for the help, FrankR. I snagged the 59 Super Seahorse Powerhead off the ‘Bay after getting your reply.
          #31415
          elgin2
            I have a 61 40hp Evinrude powerhead if that one doesn’t work. It needs a upper crank seal.
            #31445
            johnny-infl
              SandMan – if you are going to be having extra parts during your restoration,
              such as chrome pieces, medallions, etc etc, please contact me.
              I have one that has some cosmetic issues.
              #31446
                Johnny,
                That stuff is getting harder and harder to get! I regret selling all my NOS medallions now, lol
                Sandman, didn’t see this until now. I have a few fully rebuilt 35hp powerheads on the shelf that are primed and ready to be installed.
                #31856
                  Sandman,
                  I found a good powerhead for you. I have almost gotten it all torn down (1 darn exhaust cover bolt left that is being stubborn!)
                  I tested the bore, and it is true, with very minimal wear. Well within spec. It was a 125 psi motor.
                  Ill soda blast the powerhead tomorrow, assuming I get that last screw out of course. Hone the cylinder and paint it.
                  You will be back on the water by spring!
                  #31860
                  Casey Lynn
                    quote Chris_P:
                    Sandman,
                    If it was a 125psi engine…..why did you tear it down?
                    #31861
                    Casey Lynn
                      quote Chris_P:
                      Sandman,
                      If it was a 125psi engine…..why did you tear it down? At that compression the engine was well sealed to begin with.
                      #31866
                        Couple reasons Pappy,
                        First he is doing a full blow resto on a ’58 SSH, and needs a powerhead. He bought all NOS components, but needed a good crank case.
                        I had a spare crankcase, which was good. The crank splines were damaged though, as was the keyway, so had to take it apart, even though the compression was so good. Im not skilled enough machinist to repair the threads and key way in situ on the motor.
                        So, everyone wins.
