Home Forum Ask A Member Pressure tank rebuild
  • #251281
    Steve Hegge
      Rebuilding a pressure tank ..all the kits I see do not match what I have there is 2 metal disks that are part of the diaframe
      Do I need to reuse these. If so how do they come apart the seen to be soldered together
      Thanks for any help or guidance
      #251284
        The riveted diaphragm was replaced by an update kit which includes an un-holed diaphragm, a different lower support washer, and a different push button. Somebody probably will come up with the kit part number.
        #251285
          Individual part numbers for the parts in the kit are
          305713 push button
          305715 diaphragm
          305704 lower support washer
          These were the parts used in 1959 tanks.
          #251286
          aquasonic
            The pressure tanks had three different setups for the primer assembly. The aluminum button setup had two disks that were not attached to each other. The cylindrical shape button with two riveted disks on the diaphragm. And the mushroom shaped button with a single disk for the return spring.
            The riveted diaphragms are out of production, and limited to NOS. The best bet is to acquire a new mushroom shaped button, a new 8 hole diaphragm, and the associated single disk without a hole.
            Improvise-Adapt-Overcome
            #251290
            EDWARD A. KOSTIK
              What color were the pressure tank handles? They seem to be some kind of green.. Is this correct?
              #251291
              EDWARD A. KOSTIK
                What 2 sizes of fuel line are used on pressure tanks? Does anyone still sell them?
                #251292
                Steve Hegge
                  Mine are black tank red.
                  #251293
                  Steve Hegge
                    Thanks for the part numbers …looking them up now, doesn’t seem to be alot of places selling them but I’ll find one
                    Again thanks to all
                    #251294
                    EDWARD A. KOSTIK
                      Thanks!!
                      #251300
                      ede
                        Kit p/n is 377327. I do have several. Ed Elliott eddelliott@cox.net
