I’ve seen only 2 types of pressure tank diaphragms; metal plunger with cup washers on both sides of the diaphragm for the plunger’s threads to pass through, and plastic plunger with convex surface where it meets the diaphragm. The first design has a hole and the second doesn’t. But I’m rebuilding a tank original to a 1956 10hp and it has a diaphragm with cup washers riveted and a plastic button that is hollow on the bottom where it engages the cup washer.
I suppose I can drill the rivet out and use a machine screw in place of a rivet when installing a new diaphragm, with the screw head on top to clear the plunger. Anyone seen this design before? Suggestions? Keep in mind I’m typically a square tanker and I’m fixing this motor up for a grandson to use.
George
