Home › Forum › Ask A Member › Presure tank rebuild
- This topic has 13 replies, 8 voices, and was last updated 4 years, 1 month ago by
Mumbles.
January 19, 2022 at 9:51 am #253030
Good morning, I finally received a replacement diaphragm kit but am not clear on reassembly. I I checked the net but nowhere is a video or diagram to put it all back together. Anyone have anything? The new diagram has only one dic and no hole. I dont want to damage anything,any info is appreciated
January 19, 2022 at 10:40 am #253032January 19, 2022 at 11:05 am #253035February 3, 2022 at 12:26 pm #253899One more question, received the new float so I’m looking to put it all back together. I’m confused by the button in the rebuild kit both my tanks have alum shaft and nearled button the new on will not fit. What am I missing
Thanks in advance for any help
February 3, 2022 at 2:53 pm #253901What are we missing? Something is haywire with your description. What you bought doesn’t fit the tanks with aluminum shaft. Time to post some pictures of your tank.
February 3, 2022 at 8:39 pm #253916Steve,
There are two types of pressure tank push buttons that I know of. I own one of each type of tank and have rebuilt them both. I’m guessing you have the older style tank.
The new button is provided for the newer tanks. You should have no problem rebuilding yours without it. Just stick to your aluminum shaft pump button.
I don’t remember exactly how mine went back together without having to put a hole in the diaphram, but my rebuild kit had the parts to allow me to do it so as to protect the integrity of the rubber.
February 4, 2022 at 5:50 am #253927Thanks for the info makes sense now. I do have the older ones. Illmgive that a shot
February 4, 2022 at 8:30 am #253929Sounds like the diaphragm that you took apart is a nine hole diaphragm, and your rebuild kit has an eight hole diaphragm. If you still have the old nine hole, and it’s in decent shape, it can be used as a template to locate and make the additional hole required for the aluminum button assembly.
Improvise-Adapt-Overcome
This reply was modified 4 years, 1 month ago by
aquasonic.
February 4, 2022 at 5:49 pm #253979Not to slide this thread, but since we are on the topic of pressure tanks. What would happen if a fella used an ordinary cork from a bottle of wine to make the float for the fuel level indicator? Does it have to be coated or sealed with something? New ones are outrageously priced.
February 4, 2022 at 8:09 pm #254004Snyder’s Antique Auto Supply sells a float that is the exact size used in OMC gas tanks and it is made out of the new material that is not effected by the new gas with ethanol. It is part number A-9313-C. It fits 1928 to 1931 Fords.
