Home Forum Ask A Member Prop 307431
  • #9079
    RICHARD A. WHITE
      I have an OMC prop 307431, I am confused as always as to what it fits….It is 3 blade aluminum, pin drive, no splines, and 2 shallow keys opposite each other, bore of about .780
      Thanks
      Richard
      classicomctools@gmail.com
      #70215
        Here is what I have, 307431 is not listed in my 1963 price list . . . 😀
        #70217
        david-bartlett
          Richard,
          Check this listing. It looks like a number change. I found two different boxes with number 378039 on the box and 307431 on the prop.
          https://www.ebay.com/itm/OMC-Johnson-Ev … cD&vxp=mtr
          Hope this helps.
          #70223
          RICHARD A. WHITE
            David,
            I found that as well, just have not found an actual motor to connect it to definitively. Propco shows that info of 378039 being a 10X12 prop which is what this is.
            #70242
            retiredoz
              For E/Js V4s from the ’60s.
              #70243
              RICHARD A. WHITE
                Thanks 🙂
                #70249
                outbdnut2
                  In the ’60s, with your choice of props when you bought a V4, the 12 inch was the highest pitch offered. You needed a super light boat, or a twin motor setup for the 12 inch. I tried one back in the 1960s on a light Crestliner 14′ Aluminum Voyager14 with a V4 60 HP. I could get 42 MPH with it trimmed up, but It was worthless for pulling up a skier.
