Home › Forum › Ask A Member › Prop for Evinrude 5hp 5602R
- This topic has 8 replies, 5 voices, and was last updated 8 years ago by
melugin.
March 26, 2018 at 12:59 am #9494
I have a couple of 3 and 5hp right angle drive motors with terrible props. I also have a NOS 8 x 4 1/2 prop. The chewed props seem to have a cast hub, while the low pitch prop is missing a hub. The parts book and interchange books I have don’t mention hubs. Are they available, or should I just tear one out of my worst prop?
March 26, 2018 at 2:24 am #73042If the five horse is one of those mid sixties Angler motors with a detuned six horse powerhead sitting on a four horse lower, a good prop for it will be next to impossible to find. Being direct drive, they are left hand and a common 5.5 or 6 horse prop wont work. I did waste a day once adapting one and was pretty proud of myself until I realised the motor needed a left hand prop. About three years later I finally found one, in a scrap yard.
March 26, 2018 at 2:44 am #73045I didn’t need the other two props for this motor when I had them. I can’t keep everything, although I try. Yes, it is left hand, and the weedless props don’t work.
March 26, 2018 at 1:19 pm #73055OK, I see what you are saying, just saw the break down for a complete prop…
Looked up an older right angle 3hp and found the breakdown for the prop hub:
http://www.marineengine.com/parts/johns … dard+Drive
Hope this helps…Like Mumbles says, those higher pitch left hand props for the 5hps are near impossible to find, so take care of it!March 26, 2018 at 1:29 pm #73057They are around, but they will destroy your wallet compared to most other small props. If there is enough left of your old prop, you might want to send it off and have it rebuilt. The price might be the same….you’d have to check it out……it might even be cheaper than buying a NOS one.
March 27, 2018 at 8:23 pm #73126MIchigan part # 012004 or PJ7, 8 X 7 1/2, LH 3-blade , rubber hub bushing…
March 28, 2018 at 1:36 am #73144I’ve sold two of those in the last year or so for $25 each, NOS in the box. Just didn’t need them for the last 5 years. I really don’t want to triple my investment just to purchase a hub for my remaining prop. The early props didn’t use a hub insert, but the later ones did. For now, I will run my one good prop on each motor. My two plastic inserts are for the weedless shaft. This can’t be practically modified for the right angle driveshaft and shear pin location.
Thanks for the input.
My PJ-7 props looked to be solid.March 28, 2018 at 5:28 am #73147Don’t know if it’s worth looking into, but the SAC40 and SAC50 are both LH props off 5 – and 7.5 BOM ’53-’59 Scotts. Dimensions are right but they take a different hub bushing. No clue if the prop shafts are even close…
March 28, 2018 at 1:32 pm #73158I’ve checked probably 25 LH props here, including those. Close, but no cigar. I almost used a small Mercury race prop with an prop shaft shim.
