Home › Forum › Ask A Member › Prop storage dilemma
- This topic has 9 replies, 9 voices, and was last updated 8 years, 10 months ago by
retiredoz.
May 20, 2017 at 5:11 pm #7077
I have waaaay too many props, but I hate to get rid of them out of fear I may need one some day. Until I have my collection somewhat more complete, I’ll have to hang onto them.
Until that day, I need to find an efficient way to store them. How do you guys store your props if they’re not on a motor?
Thoughts? Suggestions? Pictures?
Thanks!May 20, 2017 at 5:19 pm #58059use a heavy base. add a threaded rod to the center slide the props on the rod works great. I used a brake drum. now have 6ft rack taking up no space.
May 21, 2017 at 1:55 am #58075I stack them in totes.
May 21, 2017 at 3:40 am #58086I’ve seen ’em strung up on lines and hung between rafters in people’s shops.
May 21, 2017 at 12:39 pm #58093I solved my prop storage problem……. gave a whole tub
of them away at Tomahawk….. a lot of them were
Chrysler, or which I had nothing to put them on!Prepare to be boarded!
May 21, 2017 at 12:52 pm #58094I hope I can find someone giving away Chrysler props at Tomahawk. I have a 9.6 Sea King that has kind of a beat up prop on it. It needs a few other things too, but a prop is one.
I have seen them on threaded rod posts and strings lots of times. I have them in a tote, but I don’t have that many of them.
-BenOldJohnnyRude on YouTube
May 21, 2017 at 12:59 pm #58095quote Buccaneer:I solved my prop storage problem……. gave a whole tub
Chrysler, or which I had nothing to put them on!Hey buccaneer! I will definitely be giving away many this year at tomahawk. Many of them I simply can’t identify so there’s no use hanging onto them.
May 21, 2017 at 3:19 pm #58103May 24, 2017 at 12:12 am #58222We used iron spikes driven into the logs of the garage at Houghton Lake – 84 of them, as I recall. Here in Florida I used 1/2" dowling set into the studs. Our termites love them . . .
May 25, 2017 at 6:58 pm #58315Ol rusted Merc driveshafts (the ones with the pinion gear attached) work just fine too. Stack them and put them where you have to trip over them.
