Home Forum Ask A Member Protecting plastic medallions question
  • #5405
    Randy in Tampa
      I have some medallions from 1950s Johnsons and Evinrude and I noticed that they deteriorate starting in the back, is it safe to spray primer or something on the back to keep them from this coloring process that you can see in the front of the medallion or is there another idea that I can use to protect them? 🙄
      #45045
        Use a UV blocking wax on the outside. A black acid resistant paint on the inside. A loose fitting canvas cover will help protect them from the sun. The Florida and Texas sun is most dammaging. Even Mercedes Benz will not guarantee there paint from raiding in these locations. . . 🙂
        #45048
        49hiawatha
          My experience is based on learning how to restore 1948-1954 automotive plastic colored badges/emblems.of that same time production period . Note the Korean War was ongoing and there were federal material controls which led to some manufacturers using less quality materials. Pot metal would erupt …chrome plating was marginal and I had gold plating which based on $ per ounce is now $ astronomical to find gold platers. Lastly remember that you are working with items made in the 1950s some 50 years later.
          1. Go to the car restorers plastic emblem folks..google.Source current manufacturers of similar modern emblems (2-color-3 color- 4 color).Plastics have different formulation and what works for one might not work for others (paint, cleansers,..etc.) . Note often manufactuers outsourced the emblems and used different suppliers @ times.
          2. Not knowing the quality of your plastic w/aging construction …hard to provide technical solutions.
          3. I learned , by practice and verbal instruction. I had a plastics degreed instructor(commercial plastic based jewerly) who told me this might work, BUT said you do it because of the technical variables. So I had to waste a couple. I learned how to buff with plastic rouge , different wheels compositions and speeds (burning,hazing, etc.).
          4. Research Hemmings (*Automobile) articles….Emblemagic.com…….Fiberglassics has similar questions as your OP…www.autorestorermagazine.com/car/plastic.htm
          5. The learning is thru the doing. Hope this helps.
