Home › Forum › Ask A Member › QD 21 Head bolts?
- This topic has 12 replies, 5 voices, and was last updated 3 years, 8 months ago by
Don.
June 25, 2022 at 5:25 pm #261958
Does anyone know where I can find head bolts for this motor? 10 hp Johnson QD 21. One I am working on getting 1 out as it broke off but the other 9 are in pretty bad shape. Would I be able to use hardware store bolts? I am ordering a new old stock head gasket and should I use a sealer such as permatex aviation cement on it? Thanks for any info!
This topic was modified 3 years, 9 months ago by
jimk.
June 25, 2022 at 8:46 pm #261975You can use hardware bolts IF, IF, they are the same length AND the threaded portion is at least as long as the originals. OMC was great about making some non-standard bolts. In other words, take an old one to the store with you.
Part number was 302099, might be NLA.
Personally, I’d avoid the non-graded cheapo (weak) bolts. Also, I wouldn’t suggest Stainless Steel. They might sound like a good deal, but they actually will corrode in the hole worse than the steel ones, and are harder to drill out if you should break one in the future.
This reply was modified 3 years, 9 months ago by
frankr.
June 25, 2022 at 9:04 pm #261981I used Grade 5 bolts from the hardware store on my QD-19 and QD-20. Yours should be the same – 1/4-20 bolts x 1-3/4″ length. As Frank noted, I wouldn’t use stainless steel bolts.
"Every time you remove a broken or seized bolt an angel gets his wings."June 25, 2022 at 9:29 pm #261982Sounds good! Any ideas on the use of gasket sealer?
June 25, 2022 at 10:05 pm #261983Good question on the sealer. OMC put them on dry, then later said use cement. Now, some new gaskets say don’t use cement.
June 28, 2022 at 4:39 pm #262124Use the gasket sealer.
June 28, 2022 at 8:13 pm #262131I am waiting on the gasket but been checking things over on it and keep finding problems. I expected all new ignition but found the pistons hammered by what I am guessing the wrong plugs. the head had a couple chunks broke off it but I did have one from a 10 hp Evinrude so that will work. The head had been pried off by the previous owner and there was a couple gouges on the cylinder that I will try and repair with jb weld. Might end up being a parts motor! The pistons make me a bit nervous but will go ahead and put the head gasket on and see how the compression is. The cylinders look good as in no scoring so thats a plus. Needs the lower resealed to so lots to do if I try and save it. Thanks so far!
July 10, 2022 at 7:46 pm #262773Not sure what year a QD21 is? But, if it is older than 1961, it may have worn wrist pin bushings/rods allowing the pistons to travel higher and hit the plugs/close up the gaps. Check for writ pin slop.
July 10, 2022 at 7:49 pm #262775Not sure what year a QD21 is? But, if it is older than 1961, it may have worn wrist pin bushings/rods allowing the pistons to travel higher and hit the plugs/close up the gaps. Check for writ pin slop.
Good suggestion on the wrist pin / bushing wear – the QD21 is a 1960 model.
"Every time you remove a broken or seized bolt an angel gets his wings."July 11, 2022 at 3:00 pm #262805I received the head gasket and put it back together and only 50# in top and 70 in the bottom cylinder. Its now a parts motor. It would have needed new seals in the lower and had all the original ignition so just not worth fixing but thanks for all the help on it.
