Home Forum Ask A Member QD16 Restoration
Viewing 10 posts - 21 through 30 (of 34 total)
  • #281898
    Jeff Barsch
      Got a case of good news bad news going on tonight.
      The good news is the carbon seal on the motor was the updated version.  The bad news is as soon as I started to gently twist it she gave up the ghost☹️.
      The new one is en route so I am hoping this will be the last piece then re-assembly can begin.
      1954 Evinrude 7.5 HP
      1954 Evinrude 15 HP
      1954 Gale 12 HP
      1955 Johnson 10 HP
      1956 Johnson 10 HP
      1956 Gale 12 HP
      1956 Evinrude 5.5 HP
      1957 Johnson Golden Javelin 35
      1958 Johnson 7.5
      1960 Evinrude 18 HP
      1973 Johnson 6 HP
      #282097
      Jeff Barsch
        Well I finally got this in the test tank last night and great news, she started 2nd pull.  I had to kill it right away as there was only mist out the blubber hole☹️.
        I tested pump rebuild on lower unit prior to installing and blew upper leg cooling out with air prior to installing.  I did get some air through.  Any thoughts?  Should I just keep blowing air through or are there any other tricks?
        1954 Evinrude 15 HP
        1954 Gale 12 HP
        1955 Johnson 10 HP
        1956 Johnson 10 HP
        1956 Gale 12 HP
        1958 Johnson 7.5
        1960 Evinrude 18 HP
        1973 Johnson 6 HP
        #282098
          Is the water level high enough in the tank?  The water level really needs to be above the gearcase/exhaust hsg joint
          #282100
          Jeff Barsch
            Fleetwin thanks for the reply.  I use a garbage can full up to bottom of the lower mounts so hopefully that was not the issue.
            1954 Evinrude 15 HP
            1954 Gale 12 HP
            1955 Johnson 10 HP
            1956 Johnson 10 HP
            1956 Gale 12 HP
            1958 Johnson 7.5
            1960 Evinrude 18 HP
            1973 Johnson 6 HP
            #282103
            Jeff Barsch
              I discovered the issue the water tube missed the upper grommet.  I struggled to get everything lined up but did and it pumps great!  We have snow in forecast so glad to resolve this issue before winter set in!
              1954 Evinrude 15 HP
              1954 Gale 12 HP
              1955 Johnson 10 HP
              1956 Johnson 10 HP
              1956 Gale 12 HP
              1958 Johnson 7.5
              1960 Evinrude 18 HP
              1973 Johnson 6 HP
              #282160
                Cool!  This is one of my favorite engines.  I refurbished one for a friend, wish I could have kept it for myself.  One of the nicest running engines ever built.
                #282172
                  fuel supply  going to the air pressure nipple ????  optical illusion ?
                  #282182
                  Jeff Barsch
                    Fleetwin, thanks I can’t wait to get it on a boat next season!  She sounds good and I think she will be a strong runner when I get it dialed in.  Unfortunately, the snow showed up today so think my boating is done for this year.
                    Crosbyman, not an optical illusion, I’m afraid I’m not a purist in that I convert my oldies to fuel pumps.
                    1954 Evinrude 15 HP
                    1954 Gale 12 HP
                    1955 Johnson 10 HP
                    1956 Johnson 10 HP
                    1956 Gale 12 HP
                    1958 Johnson 7.5
                    1960 Evinrude 18 HP
                    1973 Johnson 6 HP
                    #282189
                      still don’t understand why you would connect a fuel line to an air nipple ????  must be fog… pleaseexplain
                      #282191
                      Fastwin18
                        The pulsating air is what drives the fuel pump
