Home Forum Ask A Member Quince exhaust pipe
  • #297645
    Mallett
      Dose any one know where to find them, or do I start cutting and welding pipes on? Trying to go loud
      #297654
      John Schubert
        The bottom pic is the Quincy adaptor with the rare plate originally designed with vacuum cleaner pipes. The first 2 look like Quincy the evolution being 2 pipes then 2 in to one. They work best with a filler block.
        #297659
        Mallett
          Thanks for that, what’s a filler block, a shim to attach it to the motor? I’ve read all about them on the Quince pages. I have also seen a couple on kg Mercury’s in private collection’s.
          #297718
          A. Hoskins
            A filler block is a machined chunk of (usually) cast aluminum made to fit in the exhaust cavity between the engine block and the base plate of the pipes. It provides a distinct passage from each port to each pipe. They are machined to exactly match the port and block contour on one side and the pipe and base plate on the other side. The filler block gets bedded in place with some high-temp goo but not as permanent as JB weld for instance. Pipes without the filler is just a silly exercise. Wanna make noise ? Find a piece known as a Quincy dump which doesn’t need a filler block, it just replaces the stock exhaust cover. Early on, Mercury engineers found some free horsepower by just dumping the exhaust to the atmosphere.
            Certified JB weld
            #297730
            Ralph Simmons
              HELLO I AM RALPH SIMMONS
              I HAVE A RACING EXHAUST UNIT
              LOOKING AT YOUR PHOTOS
              I DO HAVE THE TOP PHOTO
              THE UNIT WITH ONE PIPE “MEGA” PHONE
              IT DOES HAVE FILLER BLOCK
