Home Forum Ask A Member "Jeweled" Morors
  • #10640
    bill-m
      Can anyone explain exactly what the difference between a "Jeweled" motor and one that isn’t jeweled? I have a 1949 Mercury KF5 and a 1962 Clinton Apache which I use Quicksilver gear oil in. Can anyone tell me if these motors are jeweled or not and which kind of lube I should be using, oil or grease? Thanks, Bill M.
      #79958
        Jeweled simply means it has needle or roller bearings. Fully jeweled means all of the bearings are needle or roller, not just some of them. I think Kiekhafer Mercury coined the term.
        #79963
        jw-in-dixie
          The KF5 is jeweled, the Clinton probably not. In general, jeweled motors will turn higher RPMs safely. Mercury OBMs dominated boat racing in the 40s and 50s for that reason.
          #79968
          green-thumbs
            Watchmakers term….jewels (usually saphire ,in rare cases diamonds) were bearings to
            prevent wear. A watch with jewels at every location where a jewel was appropriate was
            said to be fully jeweled. Advertising implying your outboards were "Fully Jeweled" emphasized
            the use of ball and roller bearings feature and implied your product had precision and quality
            of a fine watch.
            Louis
            #79969
              Actually, except for maybe the cheapest ones, the Clintons were "fully jeweled". They were derived from the Clinton chainsaws.
              #79973
              amuller
                quote FrankR:
                I think the original poster was actually asking about the gearcase, not the powerhead. I would expect that a Clinton uses bushings in the gearcase but needle bearings in the motor.
                #79975
                  The term Jeweled refers to the powerhead, not the gearcase as well. Just an FYI>
