Home Forum Ask A Member Rd-14 long shaft extension?
  • #204540
    trex014
      According to the parts manual I have they did manufacture the 25hp Johnson and Evinrudes, 51-54 style, with a long shaft extension as an option. I have yet to find a one of these with the extension or just the extension itself. I am 99% sure the drive shafts are the same as the later 50’s big twins which I have. And the shift rod will work with the 5 inch brass extension. I just cannot fine a single one of these extensions.
      Are these extensions were uncommon? or am I just not looking hard enough?
      I thought I heard somewhere that there was an extension made that went from the 55′ lower unit to the 54′ motor leg. Not sure if this is true or not.
      I will soon post an ad in the section on this website if the members think I’d be able to find them that way.
      I really appreciate all the helpful responses that come from these forums.
      #204571
        marineengine.com has a 302805 extension housing in stock. As for adapting ’55 to older models, that would have to be quite a gizmo. They are totally incompatible
        #204635
        MIKE SIMS
          I took a quick peek RD-14, RD-15, RD-15A, RD16 and RD-16A parts for long shaft are the same.
          #204746
          trex014
            Frankr thank you very much, it is on it’s way 🙂
            And oldlure, I thought they were, it’s always good to have a second set of eyes make sure .
            Once again thank you very much for the help!
