Home › Forum › Ask A Member › Rd 15 Compression
- This topic has 15 replies, 9 voices, and was last updated 2 years, 3 months ago by
seakaye12.
December 9, 2023 at 9:19 am #283112
I have rebuilt the carburetor an put new impeller in this 1953 25 hp johnson.The compression is so strong it will just turn enough to give a good thump…The only way I can turn this motor over a turn with the crankrope is to take both plugs out…Does all of these 25s have this much compression.??? MY BROTHER weighs over 200 and can not pull a turn with plugs in it.i wich there was a compression release on it.
December 9, 2023 at 9:53 am #283113I would remove the gearbox as the new impeller is probably dragging. When gearbox is off the motor, the driveshaft should protrude from the gearbox. Try to turn the driveshaft. If it is tight you will see if the impeller is dragging. If the motor turns easier I would put a compression gage on and determine each cylinder’s compression. My 1954 Johnson 25 had compression in the 90’s to low 100s.
A normal person should be able to pull the motor over with the plugs in. It will be easier when the motor is on the boat.
December 9, 2023 at 10:13 am #283115
If you have the wrong spark plugs they may be too long.
The piston may be touching the spark plug stopping the motor from turning.
December 9, 2023 at 10:37 am #283116it had J4c plugs when I got it..I put J8c in it….This motor is hard to crank with the lower unit and dri e shaft off…I tried to see if it would be easier.I don’t know…I got 3 of these motors from this guy last week…one is a1952 evenrude …the other is a johnson just like this.one…I have not worked on the other 2 ..but they seem to be the same on turning….I know they been sitting for a while …gas line dried up..briittle.I will go buy a compression gage and check it.
December 9, 2023 at 11:26 am #283118I would put oil in the cylinders to see if it loosens up, even though that will mess up your compression readings, it may prevent damage when you pull it over.
December 9, 2023 at 11:49 am #283120I bought a tester at o rileys…Top cylinder says 90….when I run the nipple all the way in on bottom cylinder it stops the piston from moving…I guess…cause it will not turn over…I backed it off one turn and got like 75….I put an extra washer on both plugs and now I can pull it to turn over…it is hard to pull ..but it will turn over…I don’t know if it would start with two washers on the plugs or not
December 9, 2023 at 11:54 am #283121I am wondering if maybe there is some carbon build up on maybe the bottom cylinder….Or would a new head gasket help???
December 9, 2023 at 11:56 am #283122I put some marvel mystery oil in the cylinder yesterday…so it may have effected the compression test today..
December 9, 2023 at 4:50 pm #283132There’s a huge difference between trying to pull them over on a stand (d….d near impossible) and standing in a boat.I regularly run RDs and even at 75 have no problem pulling them over.Leverage is the key.
December 9, 2023 at 5:19 pm #283135Thankyou…thankyou all for the valuable info .I will put it on. a boat soon as I can …
