Home › Forum › Ask A Member › RD/Big twin drive shaft o-ring
- This topic has 7 replies, 7 voices, and was last updated 5 years, 1 month ago by
olcah.
February 2, 2021 at 10:57 pm #229352
The current PN# 339543 is the o-ring that goes just beneath the splines on the drive shaft. Has anyone found a substitute or McMaster’s equivalent? Figured I’ll make good use of the shipping $$ if I’m ordering supplies anyways.
Sierra specs list the ID: to be .501 and ring thickness to be .100
My measurements of a RD driveshaft ring groove shows .535 but I’m not sure my caliper is working right. I misplaced my last new OEM o-ring for this application so I don’t have one to measure.
February 3, 2021 at 7:09 am #229359I’m hesitating to answer because I’m not 100% sure, but I THINK it’s nominal 1/2″ x 11/16″ x 3/32″. Beat me up if I’m wrong.
February 3, 2021 at 7:56 am #229360is it overly crtical to have the exact size ?….it is there to keep water out I guess not for heavy duty sealing hardware/plumbing stores should have someting similar that fits…enough
but see chart ,,,,,,,,,,,,,,,F.R. was ….pretty darn close 🙂
This reply was modified 5 years, 1 month ago by
JACQUES.
February 3, 2021 at 8:18 am #229367full page
February 3, 2021 at 8:36 am #229369On my RD18 I used an Oring with the dimensions Frank noted.
"Every time you remove a broken or seized bolt an angel gets his wings."February 3, 2021 at 10:44 am #229375I usually select an appropriate o-ring from my assorted box from Harbor Freight.
lindy46.
February 3, 2021 at 3:13 pm #229430Plug in info on left side
I could not come up with anything good
Here are decimal equivalents if you need them
id 1/2 = .50
od 11/16 = .6875
w 3/32 = .09375
https://www.mcmaster.com/o-rings/cross-section-shape~round/February 4, 2021 at 2:36 pm #229496I have also used that size on RD18s. Got mine at Tractor Supply.
