Home Forum Ask A Member RD crank case screw torque
  • #218261
    stanley
      The screws are 1/4-20.The Johnson book I have says to torque to 12-14 foot lbs(144-168 inch lbs).The standard scale I have for that size shows max of 65 inch lbs for low carbon steel screws.I am replacing the screws,are the original something special?
      #218264
        I haven’t looked them up for verification, but the higher torque would be for the top, center & lower bolts near the main bearings. 65 in/lb would be reasonable for the 1/4-20’s around the edges
        #218266
          Frank is correct. On my RD-18, I torqued the main bearing bolts to 156 in-lbs. and the outer 1/4-20 bolts to 70 in-lbs.
          #218267
          stanley
            Thank you gentlemen!
