Home Forum Ask A Member RDSL-22-CC propeller
  • #2645
    johnny-infl
      starting to get into my newly acquired 1960 40hp Super Sea Horse (Super Quiet)
      And looking for a spare prop on e-bay and there is one listed as
      PROPELLER/ PROP 10 7/8X11 305832 FROM A 1960 JOHNSON 40HP RDSL22C OUTBOARD
      My old parts book calls for p/n 277617 and 10-3/8 x 13-1/4.
      Which one would be better suited for a 1560 wood boat that weighs about 800 pounds fully loaded ??
      couple of differences to the model number from the motor tag also that I don’t understand.
      RDS-L-22-CC . . . . . I am assuming the "L" is for Long Shaft ? it fits a 22" transom.
      and the "CC" is for Counter Clockwise rotation ? and the single "C" is for Clockwise rotation ??
      #24723
        There is a large difference between an 11" and a 13-1/4" pitch. Without knowing what your RPM was before, it is a guessing game anyway. But if it was performing well before, probably not wise to make such a drastic change. The factory put the 13-1/4 on because it was best suited for the average boat the motor was likely to be used on.
        You are assuming wrongly on the "C". They did not make counter-rotating motors back then. Can’t say that I’ve ever seen a "CC" suffix, but even so, the letter designates any mid-year engineering changes—IF there were any changes. Otherwise it means nothing.
        #24728
          The prop listed on Ebay is usually used on a 20’+ pontoon boat. It could also be used for pushing barges. . . . 😉
          #24730
          Casey Lynn
            Hey Johnny, since you are a Florida Boy….are you going to the big National event down in Winter Haven?
            viewtopic.php?f=11&t=3099
            #24737
            johnny-infl
              yeppers !! got my app printed out and ready to mail….. hope to see you there
              It is only an hour drive for me.
              B/T/W – this is the same Johnny from Tin Boats LOL
              #25368
              bh
                I have a number of RD props here ranging from 8" to 13" in pitch, all 3 blades .
                Two NOS Michigan, in the box, 11-1/2 AND 12-1/2".
                I live in Sebring over the winter so coud bring some down
                if u dont find one this week
                bh/
                #25369
                vintin
                  With a total boat weight of 800lbs. I’d opt for the 10.375 X 13.25.
                  With a lighter boat weight maybe try 13.375 X 14, which I think is the factory recommendation.
                  #25370
                  johnny-infl
                    Thanks guys !!
                    the prop that is on there now is stuck. The brass shear pin is stuck.
                    The prop shaft has a groove and key as well as the shear pin.
                    So after I get it off, I can see (hopefully) the numbers on the hub.
                    #25372
                    Casey Lynn
                      You will be able to pick several up at the Super Meet. Also you have a good offer from the fellow in Sebring if he is coming to the meet.
                      #25402
                      bh
                        -regretfully not, in spite of having to scrape frost off of my car wind shield the last 2 mornings.
                        My wife says maybe later in NOV when it gets ‘cold….’r.
                        Should be a great meet though. The 1st Int Meets there at Cypress Gardens were super.
                        Bill ‘Oil Can’ Milligan, Fred Cranfield etc……
                        I know both FL clubs will go all on this one .
