Home Forum Ask A Member Rebuilding ELTO Ruddertwin Coils & Other Tips Needed
  • #5624
    wbeaton
      I am planning to restore my 1924 ELTO Lightwin Model C this winter. The motor is rough, but complete. Everything needs attention. The wiring is so corroded that even the plug wires appear to have melted. I know I can buy a replacement coil from Doug Penn for a very reasonable price, but I’d like to do it myself. I have a bin full of universal OMC coils and condensers. I also have a few Evinrude Zephyrs for parts. Does anyone have any tips for rebuilding the coils using either the OMC or Zephyr coils? I’ve found some posts that say it can be done, but nothing that shows how to do it. I understand I should boil the old coil until the insulation softens and the contents can be removed.
      Are there any other tips you can share? I will also have to rebuild the timer and carb so any information you can provide is helpful. I do have a copy of the service manual.
      Thanks in advance.
      Wayne
      Upper Canada Chapter
      uccaomci.com
      #46917
      RICHARD A. WHITE
        A few options here.. The Zephyr coil is the way to go. One word of warning… the pitch used in the original coil is nasty stuff wear protective gloves and such. Gently heating the original in an oven will warm and soften the tar to a point where the guts will come out. I have heard of others freezing the unit but I did not go with that. The end caps are sometimes held in with tacks or small brads so look for those. Be careful with the caps as the are fragile. I have one that I did, and wired up, I can get you that wiring schematic later today, if you need it, or in a couple of days that way I can celebrate my birthday today with my wife and not play with any motors…LOL I can add pictures as well, but again gimme a day or so…
        Regards
        Richard
        classicomctools@gmail.com
        #46923
          Happy Birthday Richard!
          #46926
            wbeaton—- Sent you a pm.
            Have a great day old timer!!!!!!
            #46927
            wbeaton
              Ha. Happy birthday, Richard. This is a winter project so I have lots of time. I’m just getting my ducks in a row. I have at least 6 other motors to do this winter.
              Thanks, Tubs. I’ll check my PM’s.
              Wayne
              Wayne
              uccaomci.com
              #46928
              RICHARD A. WHITE
                6???? that is it? easy peazy..lol I have about 17 I want to work on…LOL
                #46929
                wbeaton
                  quote Richard A. White:
                  No. I have 6 that I told myself I would finish this winter. There are several more in the shed awaiting attention. For the last few years I’ve been focused on restoring/repairing Feather Craft boats and a 1951 Chevy. I’m ready to get back to smaller projects.
                  Wayne
                  uccaomci.com
                  #46939
                  RICK EICHRODT
                    Before you go chopping up your Elto coil, have you checked it out to see if all you need to do is re-wire it? Simply meter the spark plug wires and see if you have continuity. If so, then there is no need to gut a perfectly good coil and install a Zephyr coil. I have had several Ruddertwins and I had good coils in all of them. It is very easy to replace the spark plug wires, install new wiring and removing the old condenser from the potted material. In the April 2006 issue of the Antique Outboarder, Sam Vance has a wonderful "how to" article for the very same issue.
                    #46942
                    wbeaton
                      That’s a good point, rickrodt. I will test the coil before I commit to anything. My concern is that the wires are all so deteriorated that I won’t be able to solder to the outside of the coil canister. I thought the canister was completely sealed inside. I didn’t know that the condenser could be replaced. I assumed it was all sealed in tar.
                      Wayne
                      uccaomci.com
                      #46943
                      RICK EICHRODT
                        It is sealed. The article details how to remove the end caps, digging out the pitch tar, removing the potted condenser (about the size of a matchbox) and how to solder the new wires, replacing the caps and such. I have done several of these and they work great. Let me know if you need a copy of the article unless you have the 2006 April issue.
