Home › Forum › Ask A Member › Refinishing 1955 Johnson Metal Hood
- This topic has 5 replies, 5 voices, and was last updated 7 months, 3 weeks ago by
Bob Wight.
August 12, 2025 at 12:25 pm #298883
I’m planning to repaint the hood on my 1955 Johnson 5.5 hp. The hood has the original paint and decals which are quite faded. I have no special tools in terms of paint sprayer or booth.
Can someone refer me to a step-by-step guide on surface preparation, priming, finish painting, and decals for a person without a lot of paint expertise?
August 12, 2025 at 1:30 pm #298884For the hood, maybe a friend has a blast cabinet they may let you use, I prefer using walnut shells as they NEVER modify the base metal. Other than that you can “scuff” the entire surface on the outside with like 180 grit sandpaper, don’t miss the nooks and cranny’s, so that the new paint can adhere to the old paint.
Another option is to use paint stripper, Citris Strip works and is eco friendly, but is slower than the likes of Aviation paint stripper.
The quality of the prep determines how good your paint “can be”.
Then the quality of the paint job is a whole nother gamble.
Hope this helps..
Richard
classicomctools@gmail.comAugust 13, 2025 at 2:19 pm #298923I’m no painting expert and I don’t have a paint booth or spray rig either but here’s a few pics from when I painted my ’54 Johnson 5.5hp hood. As Richard noted, you can either completely blast or strip the old paint off or just sand it smooth. If you’re going to the trouble of painting the hood, I think you get a better job if you completely strip it down to bare metal – I use the Citri Strip paint stripper. There’s a lot of narrative to go along with the pics that I won’t bother to type out here but you can call me at 713-927-3352 and I’ll be happy to walk you through it. Also as Richard noted, the quality of the finish paint job is all in the prep work.
"Every time you remove a broken or seized bolt an angel gets his wings."August 14, 2025 at 9:46 am #298963
No expert he says. Just look at this thing.
August 14, 2025 at 2:10 pm #298969
Beautiful, so envious of your skills
August 14, 2025 at 3:49 pm #298975Thanks Tubs and Fleetwin. I’ve restored about a dozen motors in the last few years and no doubt this ’54 Johnson ended up with best looking paint job of all of them. Very time consuming but worth it in the end.
"Every time you remove a broken or seized bolt an angel gets his wings." -
