Home Forum Ask A Member Removing flywheel from Johnson Model MD-38
  • #277074
    ERROL STILLINGS
      Trying to remove the flywheel from this little 1.1hp motor.  It has a recoil, and removing that, the dome containing the little springs seems to be a part of the flywheel. Anyhow
      the usual 3 holes that I use to install a harmonic balancer are not there.  I don’t want to pry on top of the magneto, and not sure how to remove the flywheel, as there is no spark.
      Any ideas?
      #277077
        Do a search for “Poppers” and you should see on on this site.
        Basically just a double nut with a bolt screwed into, then
        screwed tight onto the crankshaft. Have someone hold
        the motor up by the flywheel, while you hit the popper,
        and it should come loose in a whack or two.
        #277081
          Here is a video. You may be able to just
          use your flywheel nut if the threads go all
          the way trough and are long enough.
          https://youtu.be/RWgE9XiIBnk
          #277084
          ERROL STILLINGS
            Thanks alot.  Yes, the Johnson nut goes thru, and I will use that.  Have to get a bolt with the right thread tomorrow, and get that flywheel off
            that little 1.1hp motor.  Appreciate your help.
            #277120
            ERROL STILLINGS
              Got the bolt, and did the popper thing.  It worked quickly and easily.  Thanks to both of you.
