Home Forum Ask A Member Repair Johnson RD driveshaft oil seal area
  • #8263
    olcah
      I have a couple of RD18 drive shafts that are badly worn in the gearbox oil seal area, making a good seal impossible. Has anyone tried to repair these? Anyone tried a speedy-sleeve type repair?
      Thank you.
      #65077
      brian
        I’ve used the speedi-sleeve method of repairing bad shafts. The only problem is they don’t give you much width for the seal lip to ride on which can lead to problems on blind hole shafts. Price runs upwards of $40 each unless you spend some search time and find one cheaper.
        #65085
          Here’s a video installing a speedy sleeve.
          https://www.youtube.com/watch?v=Q6xghWrEmSU
          #65108
          olcah
            Good video. Thank you. I wonder if the sleeve was long enough to handle the shaft movement.
