Home Forum Ask A Member Replacement condensers for 1932 Johnson K50
  • #7276
    Monte NZ
      International Member
      Hi All
      I believe that there is a common automotive condenser that can be fitted into where the original oblong shaped ones fitted.
      The ones I have on hand are cylindrical and won’t fit.
      Unfortunately I had already made replacement cover plates, hoping that the cylindrical would fit, but it’s not to be!
      Any ideas would much appreciated.
      Thanks in advance.
      Monte NZ
      #59247
        Check these out . . . 😕
        #59250
        Monte NZ
          Hi Garry
          Thanks very much for your prompt reply.
          Looks like 22mfd in this case
          That’s a very hand chart which I will print off and file
          Thanks very much again
          MonteNZ
