Home Forum Ask A Member Replacing Vinyl Jacketed Starter ‘Rope’
  • #259991
    ede
      Does anyone have a source for vinyl jacketed cable.  Is anyone fabricating ‘new’ starter ‘rope’.  Interested in replies
      #259992
      JOHN D.
        Might be something that the sailboat people use. Furling line? This is just a guess on my part.
        #259993
          I have not used that stuff for years. never liked it. I use braided nylon
          #259998
            Haven’t seen that vinyl coated rope for a long time now.   I’ve always replaced worn starter rope with Stens TrueBlue starter rope.   Good stuff – high strength, low stretch and excellent wear resistance.
            #260010
              ?? what was the advantage of  vinyl  coating   wear protection ?
              if so why not just install some heat shrink tubing   between the handle  and spooler portion where most of the wear happens.
              #260014
                why not smooth out the ruff spots where the rope rides.
                #260021
                  good point…  🙂
                  #260058
                  ede
                    Thanks for all of your responses  This was more of a marketing question , rather than a repair question
                    #260063
                    JOHN HOLBIK
                      Clothes line should work
                      #260143
                      JOSEPH BRINCAT
                        Are we talking about the common, vinyl coated steel cable that is used for tiller steering? I haven’t bought any lately, but the stuff was available from hardware stores. Also same stuff that is used on dog run leads, pet store and Harbor Freight has the stuff. If I remember, Scott Atwater tended to use the coated steel cable on recoils in the 1950’s
