Home Forum Ask A Member Restoration of 1964 Johnson JH 19A
  • #246350
    Monte NZ
      International Member
      Hi All
      I am wondering what the slotted screw (near to the frost plug showing the model and serial no.) is for…….it appears to have a rubber type washer under it and
      is raised up between two threaded mounting holes?
      Thanks in advance for any info.
      Monte NZ
      #246384
        I’m pretty sure that screw/washer covers the crankcase port for an optional fuel pump…… Post a picture if I am not guessing properly…..
        #246423
        Monte NZ
          Fleetwin, you are absolutely correct!….. I hadn’t thought of that…….. I managed to get the screw out ok, cleaned it up and put it back with anew seal.
          Thanks for your reply.
          Monte NZ
