Hi All
I am now at the reassembly stage and was wondering if I should be using some sealer round the rubber block that the cooling pipe passes through. This rubber block has slots in either end and is mounted between the adapter plate and the trunk……..it’s interesting to note that this system is different on the 1964 to 1967 models, to the earlier 3hp models..
