Home › Forum › Ask A Member › Restoration shops in Vermont for 1948 Johnson 5h
- This topic has 6 replies, 4 voices, and was last updated 3 years, 7 months ago by
UWKite.
June 26, 2022 at 5:40 pm #262001
Hello, I’m a new member, and a new recipient (from wife for my 60th birthday) of a 1948 Johnson Seahorse TD-20 5h. A wonderful gift to celebrate the milestone. I married well.
I live in Colorado. The motor is in Vermont and I need to find a shop in Vermont that works on restoring old Johnson motors like this one. It is presently housed in Middlesex VT, just outside Montpelier.
Thank you, KiteJune 27, 2022 at 10:28 pm #262075not to many shop work on 70 year old engines hope you find one !
why not fix it yourself..great hobby lots of documenation
on the poche family site and the johnson red book you can download free as a member
go to
- MEMBERS ONLY tab
- Inner SANCTUM tab
- find LIBRARY
- Find Garry Spencer’s drop box
- go down his list off files and find the RED Book 400 pages of info you can doenload and print locally
This reply was modified 3 years, 9 months ago by
JACQUES.
JACQUES.
August 10, 2022 at 12:44 pm #264198Thank you Crosbyman. This really helps! Very much appreciated.
August 11, 2022 at 9:08 am #264224You might try calling local parts supplier, Marinengine @ (800) 209-9624. They’re headquartered in Brandon Vt.
Customer service may have a list of repair shops you could contact. If they don’t have such a list, ask if the owner, Andrew Menkart, can refer you to a shop.
August 11, 2022 at 1:30 pm #264239Many Many thanks Need2fish. Andrew was as nice and encouraging as billed. He didn’t know any shops off hand, but strongly encouraged me to try doing it myself. Well there’s no time in a man’s life when he stops learning. Thank you again, Kite
August 11, 2022 at 10:52 pm #264261You will probably just need new leather primer seals and instructions to install them. If so I am the only source for those. Most TDs of that vintage still have good coils and good compression. The original primer seals wear out so the motor won’t start long before the rings and cylinders wear out. 231-929-7479
August 12, 2022 at 9:12 am #264271Thank you Lloyd. I will definitely give you a ring for the primer seals. Leather (!!!) seals, wow what a kick! Who knew? Thanks again, Kite
