Rings are Cast Iron, Theey will flex ,but, they will break when limit is exceeded, $$$ Bottom of cylinder bore is not worn by piston travel & rings, so it will be the tight spot to set rigg gap. A used cylinder will be a worn cylinder. The end gap at bottom of chlinder can be used as a base number and the end gap measurements from several points in piston travel area will reveal degree of wear, 2 Pi R and a little number crunching will give factual information , Less than 0.005 ” increase cylinder diameter is acceptable. Oversized pistons and rings WERE available , but, That was then and This is Now, If cylinder is excessively worn out,,, lood for a better cylinder block. Hone only as much as needed,
If you check and find everything is OK GOOD!
If you check and find cykunder bores excessively worn it is time to look for a better cylinder block from a KG7
I was once told a rebuild starts with a good crankshaft, The story does not end there.
Good Luck
Louis
