Home Forum Ask A Member Rowboat motor?
Viewing 3 posts - 21 through 23 (of 23 total)
  • #26556
      Hello Hugh,
      First off, very nice original motor. Hopefully your plan is to keep it original and not restore it, as nice original examples like yours are harder to come by as time marches on.
      As far as the reversing feature it is pretty simple. In my experience There are several pieces that make up this assembly, however there are two key pieces ( clamp dog & ratchet ) that when not maintained or used correctly will cause this feature to fail. When you turn the tiller handle from forward to reverse the ratchet releases the clamp dog allowing the lower unit to rotate in a clockwise direction engaging into the reverse position. Rotate the tiller back to the forward position the ratchet releases the clamp dog again allowing the lower unit to continue to rotate in a clockwise direction engaging back into the forward position. If it has not been abused you should be able to work it through its motions by hand. ( while the motor is not running ) in all a full 360 degee rotation. It was designed to function with the motor running on the boat in the water. It will most likely not function while running on a stand. Once you get the motor running and if the reversing feature is functional. The lower unit will need to be adjust to the transom height if not the lower unit could strike the transom while shifting it from forward to reverse and back to forward again.
      Any further questions feel free to call me.
      Respectfully
      #26557
      Hugh Long
        Great, I have it on my workbench mount so tomorrow, try to warm the garage up some and give it a good looking over and checking out. I had already decided to just clean it up good. After seeing it now, I will for sure keep it original. After 7 years now of playing with vintage and antique motors, I have a better appreciation of those that can be kept original and this is one of those. Will be in touch with all as I need advice or information.
        AKA Outlaw Outboards in Fallon, Nv
        Now in Twain Harte, Ca
        #26558
        cajuncook1
          Excellent acquisition! Nice original condition. Congrats! You’ve had a very good bargain!
