Home Forum Ask A Member Ruddertwin Compression
  • #6154
    slim60
      My ’22 Elto Ruddertwin has 50 psi on both cylinders when I turn the flywheel by hand. Is this acceptible?
      #51449
      Pete
        I know nothing about that engine but 50 seems low to for a fuel ➡ compression ➡ spark engine, and wouldn’t turning by hand crank probably give low numbers ❓
        #51450
        wbeaton
          I agree with zul8ter. I don’t think you can get a true value turning the flywheel by hand. Does the motor feel like it has good compression when you turn it by hand? If not, then you probably have an issue. Otherwise, I wouldn’t be too concerned. I’d be surprised if these engines ever had much compression. You could always try to fire it and see if it runs. That’s the real test.
          Wayne
          Upper Canada Chapter
          uccaomci.com
          #51455
            Compressing ratios in the early 20’s were barely over
            4to1 because the gas was so poor so 60 lbs. isn’t bad for
            a motor from that time. Getting a motor to run can free
            up rings that are stuck from sitting and bring the
            numbers up some but your never going to get the numbers
            you find in the motors from the 50’s and be on. See if
            you can get your you motor running and see how it does.
            Run it for a few days and see if you notice any improvement.
            If you do that would indicate that the rings are freeing up.
            #51487
            slim60
              It has not run for me since there is no spark. I ordered a coil so it can be tested when the weather permits. Thanks.
              #51521
                The flywheel should turn freely through about 40 degrees around bottom dead center. If you flip it and it bounces back, you are OK. The Atwater Kent ignition system used is the most efficient system ever devised. There its no current draw unless the engine its running. The breaker points remain open at 0.009" until the flywheel is turned. The "dog bone" connecting rod rides on a crankshaft eccentric that rocks the notched shaft back and forth. These special breaker points latch on to the notch in the shaft and are pulled out increasing the point gap. When released the weight causes them the snap shut giving a millisecond pulse of electricity firing the spark plug. Lightfour and Zephyr coils may also be used. . . 😉
                #51535
                slim60
                  Thanks Gary; The Atwater Kent ignition is fascinating. I cleaned it and set the points to .009. Art is sending me a Zepher coil. The motor is clean and just some cosmetics to finish up. I’m in Wisconsin so it will be awhile till she will see water.
                  slim60
                    I pulled the juggs today and can’t believe how good this 95 year old looks. I’ll just clean the ring grooves with carb cleaner. Should I give it a light honing before reassembly?
