This is where something like the 3d printed coil housing comes into play. One can build this coil and run the motor until your heart is content, then swap the original coil back in for “display” purposes. I have tried at least 4 different times to separate the end caps from original coils… I failed every time breaking them. So I designed the 3d printed coil housing, no messy potential harmful tar to monkey with and all internal parts are easy to replace should they need be..
I can print them in brown, black or pretty much any color you want if you so desire. I can even build it for you so you need only install the coil.
Let me know, I will be at Tomahawk and will have some brown and black there if needed.
Respectfully
Richard
classicomctools@gmail.com
