Home Forum Ask A Member Ruddertwin questions
  • #2515
    bill-russell
      Hi guys, as I get to know my 1923 ruddertwin,the more I am fascinated by it.after my initial problem with starting it, I can’t believe how easy it starts and how well it runs. Thanks again for you guys help. A couple of questions, what are the Pistons made of and how many rings? I also noticed that there doesn’t seem to be any prop not cotter pin or any kind of keeper, before I run it on a boat,should I lock title the nut? I sure don’t want to lose that prop. Is there any readily available spark plug for it? That’s about it for now, Thanks, Bill
      #23737
      hotrod
        You are wise to question the prop nut. I know a member who accidentally started his ruddertwin in reverse and promptly lost his prop nut & prop into the river.
        #23760
        hotrod
          The pistons are cast iron with 2 rings each. The rings are .4061" wide.
          #23779
          bill-russell
            Thanks for the info, cast iron Pistons, no wonder this thing has lasted 90 years. Thanks, Bill
