Home › Forum › Ask A Member › Running an engine not off the tank?
- This topic has 8 replies, 7 voices, and was last updated 9 years, 10 months ago by
1946zephyr.
May 19, 2016 at 9:05 pm #4311
Hi guys I was wondering if anyone has come up with a way to run one of their motors that has a built in tank like most do without having the tank on the motor? I am specifically wondering about a zephyr. Mine keeps sucking crap through the tank and plugging up the carb even though I have tried cleaning the tank out a few times. I was wonderin if there was some way to run a line from the fuel line on the engine to a water bottle or something full of fuel I can hang above the engine. This would simply be for testing purposes to make sure I don’t have bigger issues. I still haven’t heard this old girl come to life so I was thinking it would be one way to bypass one of the known problems I have. Has anyone done something like this just to test your motor for a minute?
May 19, 2016 at 9:15 pm #36796Sure, used to do it all the time. I used an old lawn mower tank with a hose from the petcock.
May 20, 2016 at 1:25 am #36817I made a one pint (about) fuel tank out of a 14" length of 2" rigid PVC pipe, a quarter turn fuel valve, and a length of hose. It has an eyebolt in the screw cap in the upper end so I can hang it. Very safe and simple. Gas will not harm PVC. It also works fine with remote tank motors and with motorcycles, which is why I made it.
May 20, 2016 at 1:16 pm #36849A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
This reply was modified 7 years, 4 months ago by
Tubs.
This reply was modified 5 years, 1 month ago by
Tubs.
May 20, 2016 at 3:22 pm #36856How did you get it to seal up at the bottom of the can?
May 20, 2016 at 3:35 pm #36859A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
Tubs.
Tubs.
May 20, 2016 at 5:54 pm #36871get a plastic small engine fuel tank and put an inline valve on the line so you can shut it off
Doug
turned off?May 21, 2016 at 10:54 am #36911A Tecumseh plastic tank works really well and they’re cheap and easy to come by.
May 21, 2016 at 3:34 pm #36922Yep. Exactly what I would do.
