Home Forum Ask A Member SAVE A THREAD trick ?
  • #23843
      So, the tool wont work even if you pull the head off?
        Hummmm cutting the thread cleanner end off would be nice but I suspect the whole rod is dye hardenned.
        I will check my local shop for tapping if not … new head will be hunted for . Maybe Doug Penn has one ??
        thanks all for comments
        #23853
          update…..
          problem solved.
          used cyl head found locally for 25$
          Local boat dealer had several used ones in stock ….
          #23875
            That’s cheatin’, but I’m glad it is solved. 🙂
