Home Forum Ask A Member Scott Atwater 1-16 prop question
  • #7510
    ronboonville
      what are these numbers?
      #60840
        Turning the hub "adjusts" the prop’s slip clutch. Can’t say that I’ve ever seen one that worked satisfactorily. They slip too easy or not at all. I guess not at all is better, and rely on the shear pin breaking if you hit a rock or alligator. Or find a prop with the rubber hub.
        #60844
        ronboonville
          Thanks Frank!
          no gators in Missouri, yet….
