Home › Forum › Ask A Member › Scott Atwater 16 hP Fuel pump
- This topic has 5 replies, 4 voices, and was last updated 2 years, 7 months ago by
seakaye12.
August 18, 2023 at 3:36 pm #279380
Are these pumps repairable? I have one that is not pumping fuel. Are there kits available or do I need to retro fit a new one?
Thank you for your advice.
Bill
August 19, 2023 at 10:39 am #279411Very simple pump; you will need to cut a diaphragm out of bulk material. Fuel Pump Diaphragm material
Buna-N-Nitrile, appx .012 thickness
August 20, 2023 at 2:46 pm #279463Very simple pump; you will need to cut a diaphragm out of bulk material. Fuel Pump Diaphragm material
Do you have a link to that material? I looked on Amazon and ebay, but the thinnest I can find is 1/16″ (.062)
Is this the stuff?
August 20, 2023 at 3:37 pm #279466I’ve ordered from this person a couple of times over the years.
http://www.pfs-ware.com/Parts/OllieParts.htm
August 20, 2023 at 4:30 pm #279467High-Strength Oil-Resistant Buna-N Rubber Sheets and Strips
These sheets and strips offer better shock-absorbing qualities and longer life than standard Oil-Resistant Buna-N. Buna-N is also known as nitrile, NBR, and acrylonitrile butadiene. It resists fuel oil, hydraulic oil, ethylene glycol, and grease.
For technical drawings and 3-D models, click on a part number.
Sheets
- Color: Black
- Temperature Range: -40° to 212° F
- Tensile Strength: 1,500 psi
- For Use Outdoors: No
12″ × 12″12″ × 24″Thick. Thick. Tolerance Choose a Durometer Each Each 1/64“ -0.005″ to +0.005″ 40A (Medium Soft), 50A (Medium) 86715K259 $6.12 $9.54 August 20, 2023 at 9:03 pm #279476Ideally the material should be reinforced with a mesh.For whatever reason it seems rather difficult to source. A year or two ago I ended up purchasing from an e-bay vendor in the UK. Couldn’t find what I wanted anywhere else. It’s still available from them:
https://www.ebay.com/itm/313421676905?hash=item48f9634169:g:QhsAAOSwqTVgLBqM
I’m not sure what’s going on with the pfs-ware link that Buccaneer posted. I sent them a check earlier this year and my letter was returned as an invalid address.
