Home Forum Ask A Member Scott Atwater 16hp
  • #5757
    james-davis
      Old Scott 16 hp followed me home from estate sale. Turns over and shifts, couple questions. It’s red cowl, white lower, that the right color? Clean under cowl, electric start. Even has spare plugs in holder, along with shear pins. What voltage is starter? any idea what power plug looks like and where I could find one or make one. lots of questions, oil mixture, what common problems should I look for. Thanks Jim
      #47878
        12v starter. if the hood is fiberglass then red could be original. oil mix I would use 16-1 till I found out for sure.
        #47880
        retiredoz
          Book says 1/2 pt per gallon. Last year produced was ’58. I can’t find any documentation of electric start, that might have been an aftermarket option.
          The early years of McCulloch seem under-documented..
          #47886
            1957 was 12V, so it would be safe to say that 1958 was also. A model number sure would help
            image url
            #47887
            1946zephyr
              16:1? I thought those old Scotts were needle bearing construction. Those old 16’s I believe had the 17mm giant spark plugs. The old green one I had, did.
              #47903
              james-davis
                Serial number on tag is 3975-3 then 1005. fiberglass hood. anyone know what the battery plug looks like? big block to plug it in on motor front with two pegs for connection.
                #47917
                  Here ya go—
                  image uploading
                  img host
                  #47935
                  james-davis
                    That helped a lot. panel must go on the boat, no place I see on the motor. I figured it needed a solenoid.This is clean under the hood, even prop doesn’t have any dings. takes the big plugs, has two spares in holders, along with shear pins, keys. someone took good care or didn’t use much. Jim
