Home Forum Ask A Member Scott Atwater 1956 16HP Impeller Specs?
  • #157142
    seakaye12
      Can anyone supply dimensions for the impeller that is used in the 1956 Scott Atwater 16HP? Motor Model Number 3965. This was a one-year impeller as far as I can tell. Used only on the 1956 16HP Scott Bail-A-Matic. If you can….please post dimensions: Shaft ID, Width, Height, number of blades etc. The Scott Atwater Part number is 3965-5100
      • This topic was modified 7 years, 3 months ago by seakaye12.
      #157406
      seakaye12
        bump
